Omron CX-Programmer simulation problem
Light
Sep 2010
Doha
hi
I'm very new to this technology, and my question is very basic.
i tried to do simulation in the CX-programmer for a very simple program, but the simulation tool won't appear, you will understand when u see the picture below:
im using cx-programmer v6.1
please help me...i really want to be professional in PLC programming and installing.
thank you
well i have that icon too in the 6.1 :
but i still can activate it !
just take in consideration that im a beginner that can miss somthin very basic.
tq
nope....still won't work...even after checking the list...and making sure that im using CS1H-CPU67 ! :(
can it be from the serial ? i already got 1...but i dont know -_-
can any1 give me a serial to give it a try ?
HMMM!
Works for me just fine with a CS1H-CPU67!
Right click on PLC.
Select "Change"
Select "Network Type" = Toolbus
I am using CX Programmer V9.12.
Could be a version problem but am NOT sure.
i still couldn't activate the simulator....please help me!
how can i download the cx programmer V9 or V8 ?
please help me im wasting my time :(
i installed cx-programmer V9
and its working :)
thanks for everything
i'll be back for programming questions :)
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
385
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
746
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,987
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,069
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,302
