omron cx-programmer
NIMAMOGHTADER
Aug 2007
RASHT
hello,
i have a straightener press machin that in this machine use omron
c200hs-cpu21 with one positioning unit (nc111).and one high speed counter ct001-v1.i have a fix lit errod led on my nc111 and ct001
card.i think my parameter that must be in this two card erased
because my backup battery was empty.and i download my backup that only pick from program (with out data).i guess my data in this two card erased.can anyone help me for this problem or give me a file
that i fill parameter of my stepper motor and download it to plc
via pc ,for example.
Unfortunately, the data will need to be reconstructed.
The configuration data for the modules will depend on how they are being used in the program.
CX-Programmer starting with v6 has I/O unit setup tool in the I/O table utility. This may make your task easier.
If you are using an earlier version, you will need to get the manuals for the modules and figure out the proper values for the configuration words.
Is it possible to contact the machine builder to see if they can provide this information?
Good Luck.
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
400
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
757
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
2,010
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,082
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,316
