Omron (CX-Programmer)
King-snorre
Dec 2014
Norway
Hallo,
Have some questions, I've been doing this old Omron C200HG
and I am now going to use CJ2M, but i have a question what does this sign mean??
WUA+ctyCUcfUNTB1DUxdA1PXwNQ1MHUNTF0DU9fA1DUwdQ2+Q4Y84zFv3LMAAAAASUVORK5CYII=
i know the adress but I have never seen this sign before, please help!!
That's an "immediate refresh" of the normally closed I/O point. It means the PLC will get the current state of the I/O point instead of using the state at the end of scan I/O update.
Thanks, that helps allot!
I have used this differentiate put then it comes up an arrow, pointing down or up.
Are you good in the old C200HG PLC?? :)
Just fired up CX-Programmer and added some dummy code.
Looks like that is a contact from a DIFU instruction.
Top rung shows a DIFU contact, and Immediate Refresh to a DIFU instruction.
Second rung show a contact from the DIFU instruction to a coil.
Just wanted to verify the symbols.
Hope this will help.
HR is the Holding Relay area.
This memory area is valid in both C200HG and CJ2M processors.
C200HG will have 100 channels of HR (H00-H99). This can be addressed at the bit level (H00.00 - H99.15).
CJ2M will have 512 channels (H00-H511), also addressable to the bit level.
HR memory will retain on / off status through power failure.
I remember when the C200HG was introduced, as do a few others around here.
Hope this helps.
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
394
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
753
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,999
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,077
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,311
