Omron EJ1 Devicenet
jrexrode
Mar 2005
Upstate, South Carolina
106
Has anyone here set up the Omron EJ1 temp controllers on Devicenet using RSNetworx. I can get the Omron DNET adapter to communicate properly using the simple allocation method as long as I don't mix the 2 loop and 4 loop modules, but when I mix the modules, things seem to get screwy. I haven't been able to find an EDS file for the Omron comm adapter either.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
260
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
146
