Omron encorder with mitsubishi plc connection
Hasitha
Dec 2015
colombo
44
Dear sir,
I need to connect my encoder with mitsubishi PLC and take the encorder values to plc . My item specifications are as below.
PLC is Q series having QX81 digital input card.
Encoder is OMRON E6CP-AG5C absolute rotary encoder.
plz be kind enough to give the relavent pdfs regarding this. i have tried so many searches on the gogle and still i couldnot get what i want. :( Also if you can give me the pdf relevant to do the same action with QX41 input card.
Thanks & Best regards,
HASITHA
The Omron encoder E6CP-A uses a gray code output.
Gray code output will need to be decoded in your plc logic.
The attached example is for a different Omron encoder and logic example is for an Omron plc, but the concept is the same and will work on your Mitsubishi plc.
Hope this will help.
thank you alot for the quick response. i dont need very high speed use there.i saw that one machine builder has coupled that encorder with qx41 card, i need to know how to do that as well to do that using qx81.
plz give me help here...
Dear gtsuport,
Thank you very much for your kind help.it is something very useful that u sent me. im a mid level plc programmer and i think its better if i can get more helpful links regarding this matter.
This is my first time im going to deal with an encoder. :p
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
162
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
106
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
140
