Omron Force Bit Cancel via Fins
xcanowarx
Jul 2015
turk
Sometimes I forget to cancel forced bits in omron CJ2M-CPU34 PLC. I want to cancel all forced bits automatically and found something about fins command. I'm now facing difficulty in activating the all cancel forced bits command. (2302) Is there anybody know how to use @CMND command for cancel forced bits?
In CX-Programmer open options - PLCs and tick the box to let you know there are forced bits on when exiting - then to will not forget.
Hi BobB thanks for your answer. i did this before but our maintenance team members forgot again force bits. I'm looking for the option to cancel with command. We also use Omron NS8 HMI which connect via ethernet. Maybe i can use NS8 HMI for cancel force bits.
Hello, Since it's been almost 4 years since I've used Omron PLC"s, I can't seem to remember how to force a bit using a handheld Omron SYSMAC...
5,164
Hello. The command for force set is: @ a b K S OP1 OP2 OP3 OP4 W1 W2 W3 W4 BIT1 BIT2 FCS1 FCS2 * [ent] a,b = Unit No. OPx = Area Wx = Word...
2,690
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
132
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
100
