Omron FZ4-L355 Vision & Profinet
Mike_RH
Sep 2006
Toronto
896
Gents,
Does anyone have any experience with this Omron vision system and a Siemens S7-300 CPU using Profinet?
The Omron does not support Profinet, but does support UDP / TCP connections. Has anyone doen this? Or would it be easier to use something like an Anybus adapter?
All comments appreciated!
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
259
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
146
