OMRON induction motor
faycal86
Jan 2009
Algeries
I am using OMRON CJ1M CPU 11 PLC with CJ1W MAD42 Analog I/O Unit
to control speed of an induction motor using a PID controller in a closed loop .
so I will use 1input(to plc ) to read the speed and 1 output (to motor) as setpoint value.
I need memory areas and range code to specify the range of the voltage
thanks
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
47
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
74
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
272
