Omron Last Print Duration
bopol
Feb 2008
Singapore
46
Hi guys,
Just want to know if there is an easier way to do the below function using Omron CX Programmer (Cj2-CPU13).
Function:
1. Press Print
2. Date and time "saved" to currDate memory (retained)
3. CPU serial port sends text string to text printer thru txd_cpu command. Included in the printed text is the Current Date and Time and the Last Print Date and time (inititally, current date and last print date is the same)
4. After Printing is finished, currDate is "moved" to memDate
5. Press Print Again, the currDate memory is updated.
6. Printer Prints the Current Date and Time and the Last Print Date stored in memDate.
7. After Printing, the memDate is updated.
*Current Date/Time and Last Print Date/Time is input as string in a FB before printing
***This Part is Done***
Additional Requirement:
1. Add the "Duration" from the last print date to the current date in the printed text.
Ex:
Current Date: 4-10-2012 12:30:30
Last Print Date: 3-10-2012 14:20:30
Duration: 0Y 0M 0D 22h 10m 0s
How I am planning to fulfill the addt'l req:
1. extract the following strings: Day, Month, Year, Hour, Minutes, Seconds (both current and memory values)using the MID$ function then convert as integer.
2. Get the duration by using the attached FB "Duration FB". (I haven't actually written this in CX programmer yet, will be able to do it later at the office).
3. Convert the results back to string then include in the printed text.
o_Oo_Oo_O
If any of you guys have done something similar or know of a function that could do what is required, please point me in the right direction.
P.S. this is only my second time using Omron so i am not very familiar with the functions yet.
TIA and regards,
Paul S.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
180
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
72
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
112
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
267
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
153
