Omron NB event screen
andepand
Jan 2017
Amsterdam
72
Hi.
For a project I’m programming a 10 inch Omron NB hmi. Now, creating an event or alarm screen is no problem, however all event related screens have the same small font.
I want to decide myself how I review ongoing events, in this case I want a bigger font and different color.
Any ideas?
Thanks,
You can change the font in the alarm property dialog box.
NB-Series-Programmable-Terminals-NB-Designer-Operation-Manual.pdf
Thanks man, I was looking For settings in the event/alarm screens. It didn’t occur to me that I can change the font in the actual event list.
Thanks again, case closed.
CJ2M I want to hide the alarm window unless there is an alarm. Is it possible to only display the alarm box when a certain bit is triggered? if so...
1,569
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
259
