Omron NT 31C Com Time Out Error
naveed1705
Mar 2006
Karachi
My unit is showing an Error " No Screen Data is saved in memory.
Download Screen DAta using by the Support Tool. ..........."
I have installed NTST4e in my system , when I load NTST system Installer and select the same omron unit which i want to connect
and then I prees Go button.
the question is that I want to know how to connect NT31c to the software .
The error message is telling you there is no screen information or "application" in the NT31C. The system installer loads the "executive" program into the NT31C, your unit already has this loaded.
To access the menus in the NT, touch two opposite corners on the screen. Then touch the "Transmit Mode" button, then the "Tool Transmit" button. In NTST you need to have the project or application file open, then click the "Connect" pull down, then "Download", then "Application" to send the screen data information to the NT31C.
Use this cable between the computer and the NT31C:
Omron Semi Universal Cable at Mr.PLC.com
Hope this will help.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
298
hi hello every one . i have a Omron nt31c hmi and i want to connect with ls plc XBC DR60SU via rs232 . do any one now how ?? secondly :i have...
202
Hi, I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C). In order to connect a PC to them, I want to know: 1- Is the cable...
875
Hello, I have an Omron NT31C that I am trying to upload a screen to from my laptop. The software on my laptop is NT-series Support Tool ver...
1,886
Hello I have salvaged a Omron NT31C-ST141-EV2 from a piece of LAB equipment. I put power to it and the screen lights up with the words "Please...
4,938
