Omron NT20M terminal communication problem
thegreen2
Jun 2013
quebec
Hi, i have a NT20M programmable terminal with a NT600M serial interface installed in a old machine. everything work except that i want to backup the program but i cant communicate with it. I tried with support tool 4.8 but i have this error message "incompatible PT hardware connected" After that i tried with an older version of support tool; 2.33 but again im not able to communicate. Is it the same cable between 4.8 and 2.33? If i am not wrong 4.8 support tool support NT20M?
Can it be possible that my problem came from my lap-top? ntss2.33 only use com1 or 2 and when i use nt support tool 4.8 i must use the com5
Hi everybody I have a new NT20M OMRON Programmable Terminal linked at a Mitsubshi PLC. When I'm turning on the power, the device (NT20M) boots and...
5,521
hey, I have an Omron NT20M panel connected to an Omron C200H PLC. I need to modify both NT20M and C200H programs. I made uploads of both NT20M...
7,395
I have PT software Support Tool V2.33, NT20M and CQM1 PLC. I want to control Bar-graph and LAMP in NT20M by CQM1 Refer software Support Tool...
5,702
I have Touch screen NT20M and use NT software version 2.33 (dos version). I can't up load data from NT20M to PC via RS232C because i not't have...
5,347
Can anyone point me in the direction of a "user manual" for the NT Series support tool software, the version i have is 2.33. Also I've downloaded...
6,135
