Omron NT620S
RoTaTech
May 2003
Cobourg, ON, Canada
418
I have a unit that pre-dates me, and it shows a Kanji character where it should have a space.
They are on *every* screen, including the system screens, so it is not an application program error.
There are other identical units in this plant with no such problem.
Has anyone here seen this before, and if so, how did you rectify it?
Thanks ΣΔ. But I have done so several times. The only thing I have thought of is the firmware somehow got change to Jap'. The DIP switch is set for Eng'. My Updater refuses to communicate with the screen - constant time-outs.
I am awaiting a reply from Omron TS, but thought I would try here as well.
Not had it on an OMRON but had something similar on a Beijers HMI, It was to do with the fonts, had an original system on the plant, the HMI died so re-programmed a new one (done this many times) but for some reason some chars especially the spaces seemed corrupt, tried many times, showed ok on the laptop, eventually replaced the font type (long process had to edit every field for that font) & it worked, although never looked into the problem but it appears that upgrading my laptop from NT to Win7 (new laptop) was the cause, when I tried an older XP laptop with the same file it worked fine.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
137
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
100
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
136
