omron NT631C-ST
hodgie_2k
Jun 2010
NE
24
i am having problems with a omron NT631C-ST HMI screen. all i am getting is System Initializing screen it wont access the menu screens. i am wanting to wipe it and upload a new program.
can anyone help with this problem?
Cheers
Cheers
I am not sure how much experience you have with the Omron NT HMIs, so forgive me if you know all this. Push any two corners on the HMI Screen at the same time, and this should access the Internal Menus. Then you can select Maintenance, wipe all the Screens and Data Files. Then go to the Transfer Screen, and download your application with NTST. This is all from memory, as I don't have an NT Screen in front of me right now.
Stu.....
cheers stu
i tried that a couple of times before it worked. i dont think i was pressing it hard enough
yeah everything is working fine now, my next mission is to get the program uploaded to the PLC then link the two together
Glad to hear it. If you have any problems, by all means post them. I have set up quite a few Omron NT and NS Screens. There are a number of other very knowledgeable people with Omron on here as well. Good luck!
Stu....
Hello
I am trying to link a Omron C200HS CPU21 to a NT631C screen. do i need a host link unit?
are there any documents to help me out?
cheers
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
286
Hi, I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C). In order to connect a PC to them, I want to know: 1- Is the cable...
874
hi, i have omron nt631c-st153-ev3 not connected with that cable, all the time it has an Connection time out Error..?? can some one tell me...
1,395
I want upload program from Omron NT631C-V2(system ver.3.1) to computer PC with "NT-series support tool". How to make cable for this connection?
3,800
can anybody help me? i have a Omron C200HS and a NT631C screen i have no idea how to get them to run together. i am new to omron how do i set...
7,028
