Omron NX-ECC203 Ethercat coupler I/O Issue
A_J_J
Oct 2023
Texas
Afternoon all,
So, i have an output that is being fired from 2 inputs separately. 1st input is a sensor, when something passes by it should trigger an output to be fired. 2nd input is a "test" button, when the button is pressed once, the output should fire 10 times in succession. for about 75% of the work day, this process works as intended. for 25% of the day all of the sudden the output will no longer fire. both inputs are able to be made back to the card, but the output never energizes. It does this until the power is cycled to the PLC then everything works as intended again.
Side note: The facility is still under warranty and i do not have authorization from OEM to go into the code and make changes. i am however able to get the programmer on the phone and explain the issues to him. that being said im hoping i can better direct him where to look where the problem may be. i believe is has something to do with a latching/ unlatching bit? possibly a watchdog timer having issues. honestly not sure until i can get a look at the code for myself. any help would be greatly appreciated if anyone has seem something like this before. Thanks!
EDIT: The programmer is in germany so getting him on the phone when the problem actually occurs is near impossible.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
157
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
104
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
140
