OMRON PLC newcomer
grnick50
Nov 2010
Ptolemaida
332
Dear all,
First of all I want to wish you Merry Christmas.
I currently support Siemens, AB, Schneider Electric and I wish to start working with OMRON PLCs. I am researching on what tools I have to purchase to start off.
Could you please give me a head start my proposing the required tools like cables and Software.
I would be more keen to a universal solution, like
a cable adapter and a software for all OMRON PLC series (If possible).
Regards
Nik
CX-One software covers all the latest PLCs, most of the older PLCs, touch screens, networking, drives, temperature controllers and motion control. Also covers Profibus, Device Net, CompoNet, EthernetIP, routing tables.
Cables vary depending on models. You only need a standard USB cable for the CP1 series and the CJ2 series PLCs. Nothing special. For others post what you will be connecting to and we can advise which cables you will require. The NS, and some other, touch screens also only require a standard USB cable. For Ethernet connection standard Ethernet crossover cables are required unbless your laptop Ethernet port has auto detect and then a standard Ethernet straight thourgh cable is OK.
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
171
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
137
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
198
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
127
