My question is as follows I have to install an 8-point relay at work and I am not too familiar with control work. The purpose for this relay is to prevent a pump from starting unless another component is running. I took a quick glance today and it seems I can use existing 120V to power the relay and find a set of n.o. contacts to switch on the indication light for the pump to verify it is ready to run. After that it becomes tricky for me, because I need to somehow tie into a pushbutton that starts the main component. They both have different power sources. Help Please.
