Omron RFID systems
Steve Kemp
Nov 2003
122
Has anyone used the Omron CJ1W-V600C12, two channel rfid tag reader module? I figured that the "plc module" system would save the hassle of a serial interface and associated programming. Right choice? Anecdotes/cautions? And yes, I know they're on 3-month lead time :mad:
Cheers, Steve.
Steve,
I have not used this module and I could not find a manual on-line either. However, I have worked with other Omron RFID modules, and you are correct. The data should be directed to either CIO or DM for information read from or written to the tag.
If the lead time is a problem, there are Protocol Macros written for the serial RFID controllers. This would make it a bit less painful. You would need a SCU module to utilize the Protocol Macro function.
Hope this helps
We have set up demos for our customers using the Balluff RFID system on Devicenet. If you already have a network in place, then using something like this is easy.
I'm sure other manufacturers also have networked solutions.
<Disclaier... I work for a Balluff distributor>
Hello all. Firstly, has any one used the Omron V600-H11 and H51 RFID heads? Here's the problem: I need to break the "as suplied" cabling from...
2,900
Hello everyone, I am a student at Humber College and I ran into an issue regarding the communication between 1756 ControlLogix Allen-Bradley PLC...
3,726
Hi all, I have attached my code. I connect with PC via Peripheral, Unit 0 node 1 (192.168.55.1 )connect with DiGi Connectport TS W...
1,625
Hi all, I have project to read/write data with Omron V680-CA5D01-V2,V680-D1KP52MT, and PLC Omron CJ series but i don't know about protocol. How to...
2,264
Hello I was wondering if anybody has any sample code to communicate between an omron plc CQM1 and RFID unit V680 series. I would be very basic...
1,270
