Omron servos
Steve Kemp
Nov 2003
122
Hi all. Currently trying to breathe some life into a new R7M series servo connected to a Smartstep drive. It's the 750W version (no brake). "Out of the carton" the rotor was locked (with no brake?), but I'm told it's "servo-locked"... So, tick all the boxes for power-up and enabling and it's still locked (definitely not servoing to a static position). Anybody out there had experience with these? I must be doing something wrong -as usual.
Thanks, Steve.
Steve Kemp said:
..."Out of the carton" the rotor was locked...
The drive should lock the rotor only when powered and enabled...at least the brands I have worked with operate that way. Out of the box, disconnected did it freewheel easily? Normally, a brake motor is locked with power removed, and a non-brake motor freewheels. Maybe they got your part numbers crossed or just sent you a bad device...
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
177
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
263
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
146
