Omron special I/O and expansion rack query
sturtles
Aug 2006
sing
Hi guys,
I have a main cpu rack with 1 MAD01, 1 SYSMAC Bus and a PLClink module special I/O units in order. The CPU is CS1G
How do I set the unit knob on each of these devices? Do I set them in 0, 1, 2 or 0,0,0 as they are all different special I/O devices
I have another expansion rack number 1 with 1 MAD01. Do I set this MAD01 to unit 3 or unit 0?
The start address for my main rack mad01 is CIO2000, so does the mad01 on the expansion rack be CIO2010 regardless of the unit settings?
Thanks all for reading.
Thank you very much
Thanks guys!
My unit is (LHS)C200H-MAD01,Sysmac Bus unit,PCLINK unit, CS1G CPU(RHS) on the main rack, and 1 c200h-MAD01 with 2 I/O cards on the extension rack
For ease of setup, I set the main rack MAD01 to unit:0 (CIO 2000), and the extension rack MAD01 to unit:1 (CIO 2010). I hope this is correct
I'm a little confused by the other 2 special I/Os on the main rack, namely the Sysmac Bus(RS232/422) and the PClink unit. Do I need to set their units to 1 and 2 respectively?
Just to clarify, on extension racks, does the special I/O units numbering continue from the main rack, or do they start from 0 everytime?
Thanks PP!
Am I right to say most special i/o cards are only dependent on order of the same type, ie mad01 for the units adjustment, regardless of extension racks and special i/os of other types?
Hello, I have a problem with installing Omron DA004 card in the C200HX PLC. In CxProgammer it keeps giving me "Duplex / Special IO Unit...
3,357
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
180
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
73
