Omron Sysmac mini SP10
R_Serif
Aug 2009
Williamsville, NY
Can somebody help me finding the programming software for Omron Sysmac mini sp10 ? I tried to use the Omron CX-One software but this unit is too old and not listed under proccessors name. There is no communication with the proccessor.
Tx.
Remzi
One of these will work. I believe it is the first link. Most likely will need old computer with real RS232 serial port and windows98 or older operating system running in DOS mode.
The download button is almost hidden at the bottom of the webpage.
http://forums.mrplc.com/index.php?autocom=downloads&showfile=82
http://forums.mrplc.com/index.php?autocom=downloads&showfile=81
See this thread for links and info on cables, manuals, and software. Be sure to read the whole thread, some of the links don't work and some of the info is not totally correct.
http://forums.mrplc.com/index.php?act=ST&f=17&t=347
P.S.
Here is a link with info on using very old software on newer computers. I have no idea if it will work for the Omron or if it is of any help. Others have said it works fine using it on an old SLC150 AB PLC, software, and interface.
Link:
http://www.plctrainer.net/DOSBOX.pdf
If you still have problems, please feel free to send me a PM. I may have some more info available.
We have an old Omron Sysmac Mini-SP-16 (photo attached) running a tin tag stamper. It appears the internal power supply has begun looking into...
5,337
I've been asked to get the program out of a old OMRON sysmac mini SP16. From the Manuals I have found it looks like I need a hand held programmer...
6,067
Could somebody help me with the old Omron Sysmac Mini SK20 PLC? I need a software and a cable diagram. On the forum is the link but unfortunately...
5,324
F
Can somebody tell me where to get free or cheap software for ladder logic programming for the Omron Sysmac Mini SK20 PLC that I bought recently? I...
6,352
R
Hi , I am using this omron plc which is a sysmac mini sp10. I dont know the adresses that i have to use since it is a very old plc and i dont...
8,719
