Omron Zen 10C3AR-A-V2 Output no Amps
plewis
Nov 2010
Michigan
I have a Omron Zen 10C3AR-A-V2 and the logic is setup to run a cycle test with time delay on/off settings of 5 seconds. The entire program works well and monitoring the program shows the output turning on/off properly.
However, after connecting the output device to the output 0 location I am seeing no power (actually I show 60 mA) which to me means its just switching on/off and not supplying the need AC power.
Any suggestions? Please let me know if more information is need. I was wondering if the Omron Zen 10C3AR-A-V2 unit has some type of internal setting that will ensure voltage to the output.
The output is basically a relay contact.
You will need to supply voltage to one side of Q0
and your device would be connected to the other Q0 terminal.
Hope this will help.
I am very new so I will try to give as much information as possible. I cannot get a Prolific PL-2303TA USB to RS232 to connect to an Omron ZEN...
1,595
Hi, after 30 years involved with automation I'm actually writing my first PLC program and am struggling a fair bit. My background is mechanical...
1,885
Hi I am setting a system up as per the attached picture, 5 inputs that are always present. These are sensors I have in an injection mould, if...
1,865
Hello all, new on here, and relatively new to plc programming. I am trying to write a program which counts as it receives a cycle end input, and...
1,902
I am trying to write a program for a omron zen plc. 1st light on for 30 sec 2nd light on for 12 sec 3rd light on for 3 sec then start all over...
1,332
