Omronc200hs-connect to NEc barcode scanner
GanShan
Jan 2006
Singapore
CAn any one please help me .. How to use a LK201 -v unit with an C200HS Omron plc ..to receive data from a NEc barcode scanner ?
BArcode scanner is 9 pin RS232C port and LK201 -V 25 pin rs232 , where to get pin config for lk201 , and any example program ...
please help
Sorry, the LK201 unit will only communicate Hostlink. Only option to connect a barcode reader to this cpu would be an ASCII/BASIC module.
It might be worth thinking about upgrading the processor to a CS1. You could reuse the IO modules and the barcode scanner could connect to the RS232 port on the cpu.
Hope this will help.
203
97
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
343
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
