piscis Member P Join Date May 2003 Posts 241 Sep 12, 2006 #1 On GE VersaPro what is the instruction to use to run the ladder logic 20 rungs only instead of the entire 100 Rungs program? In Koyo PLC’s you can place the END instructions anywhere, what is the equivalent in VersaPro?
Steve Bailey Lifetime Supporting Member + Moderator Join Date Apr 2002 Location The boondocks of Western Massachusetts USA Posts 8,591 Sep 12, 2006 #2 You can place an END instruction anywhere you want. The END instruction must be the only instruction in the rung. It can not be conditional. It is intended as a debugging tool.
