GE Fanuc VersaPro Ver 2.0
1. Subtract Minimum Engineering Units value from Maximum Engineering Units value and save the result.
2. Subtract Minimum Raw Data value from Maximum Raw Data value and save the result.
3. Divide the result of #1 by the result of #2 and save the result.
4. Multiply the result of #3 by the current raw data value and save the result.
5. Add the Engineering Units value when the raw data value is zero to the result of #4.
I don't find any usage of %AI39 in the project file you send to me.
However, scaling of analog signals is done in the program block, "ANALOG".
For each analog signal:
Copy the maximum engineering units value to %R20011
Copy the minimum engineering units value to %R20013
Copy the analog signal value to %R20015
Call the subroutine "UE_VAT"
The scaled result is returned in %R20025. Copy that value to the address you will use in subsequent logic.
Needing a bit of help on some GE Series 90-30 configuration files. It appears that I need the GE VersaPro software at a minimum to view the data...
2,411
Hi Everybody, I have inherited an old GE Fanuc project where the PLC program has been wiped from the PLC. I have the Proficy Machine Edition...
24
27,054
Hi, let's see if someone can help me here. It's the first time I work with a GE FANUC PLC. The client gave me the backup files they took from the...
7,135
I'm having trouble establishing comms with a GE Fanuc 90-30 Series PLC using using VersaPro v2.03 software. When trying to connect via...
5,152
Could someone tell me what the letters mean in the program made in VersaPro? i.e. I,Q,M,R. I assume that the "I's" are inputs, "Q's" are coils...
2,456
