GE Fanuc VersaPro trial software
benhutchy
Feb 2014
Lara
Hi Everybody,
I have inherited an old GE Fanuc project where the PLC program has been wiped from the PLC. I have the Proficy Machine Edition software and can get online with the PLC but the program is gone. This machine is about 10 years old and I have a copy of the original PLC program but it was created in VersaPro. I tried to import the program into Proficy but I am missing the .fld file. I have the .flb backup file but I cannot use this unless I have the VersaPro software. I need to get this machine up and running as soon as possible and I was wondering if anybody has a copy of a trial version of VersaPro so that I can create a .fld and import the project into Proficy for future use, or if I upload the file can someone with VersaPro possibly do this for me?
I appreciate any help.
Kind regards,
Ben
Post your VersaPro backup file here. I have both VersaPro and Proficy Machine Edition. I can open the VP backup, and import it into PME for you. What version of PME will you be using?
You will need to change the file extension of the VP backup from .flb to .zip to attach it. That's a quirk of the forum software.
Hi Steve,
I have attached a zip file that contains a folder with the original VersaPro PLC program and the back up .flb file. I have access to Proficy Machine Edition 7.0 and 7.5 so it doesn't matter which of these versions is used.
Thanks Stave I appreciate the fast response.
Kind regards,
Ben
Hi!
I have one question
how can I open C Blocks in Versapro?
I have some C Blocks in example code, but I cant open any of them.
what I can to do?
I have GE Fanuc VersaPro 2.0 software where can I get an upgrade CD. I need to program a IC200UEX164 64 point (40) 24Vdc In; (24) Relay Out; and...
26
2,206
Needing a bit of help on some GE Series 90-30 configuration files. It appears that I need the GE VersaPro software at a minimum to view the data...
2,411
Hi, let's see if someone can help me here. It's the first time I work with a GE FANUC PLC. The client gave me the backup files they took from the...
7,135
I'm having trouble establishing comms with a GE Fanuc 90-30 Series PLC using using VersaPro v2.03 software. When trying to connect via...
5,152
Could someone tell me what the letters mean in the program made in VersaPro? i.e. I,Q,M,R. I assume that the "I's" are inputs, "Q's" are coils...
2,457
