Hi everyone,
If there is similar thread I apologise, please point me to that direction if there is, but I didn't find it.
So, I'm using Delta DVP-14SS2. What I want to do is:
1. X0-ON --> START (stays on when push button is released)
2. X1-ON --> STOP (stops everything, or turns OFF X0)
2. When X0-ON it turns ON Y3 (which is piston-forward in my application)
3. When piston reaches limit switch X5 it should turn OFF Y3 and turn on Y4 (return piston)
4. When piston reaches limit switch X6 it turns off Y4 and stops the cycle until X0 is turned ON again.
X2 and X3 are for manual operation without limit switches restrictions.
Here is what i did so far, but I can't figure out how to implement steps 3. and 4.
Any help or if you can direct me to some example from which I could learn I would be very grateful.
Thank you in advance and regards from newbie in Croatia.
Marko
Marko
