Online PLC5 Ch0 reset?
Gyprat
Jun 2010
South Carolina
Maybe someone ran into this before.
Sometimes Ch0 stops working on a PLC 5/60 processor. The only way we know how to reset it is by cycling processor power. Obliously it is hard to do when the plant is running.
Is there a way to reset it throuth the RSLogix 5 software while the processor is in RUN (or Rem. Run) mode?
We only use CH0 to send short ASCII code to a printer several times a day. Plant engineer tried replacing the processor but the problem is still there. It's been working fine for several years and just started doing this several weeks ago.
I have seen this before with a PLC-5 receiving ASCII data from a vision system. In my case, the problem was persistent, and could go for a day or so before there were issues. I added extensive error trapping/buffer dumping code and got it to work for up to a week at a time. In my case, I could reset comms effectively by power cycling the vision system. I don't recall the details of what I did in ladder logic to help, but it wasn't really anything special and didn't fully solve my problem.
Since yours has worked fine for years, I must ask if something may have changed at the other end? Perhaps a degraded comm cable picking up noise?
Also, can you power cycle the printer and get comms back?
Cycling power to the printer does not help. We tried to connect to Ch0 with a laptop running Hyperterminal. No response from the processor.
I don't have the manual at hand but sometimes print commands have a queue that can get full and needs to be cleared. It might be worth looking into.
Hi, all: we have PLC5/40E, offline file has comments, but online file has no comments. for sure online file and offline file are different, any...
1,701
I connected PLC 5/40B processor to win Xp3 PC using U2Dhp cable. I was able to see processor connected on RSLINX 2.57. But I am not able to get...
1,720
Can't perform online edit on a PLC5. My problem is similar to this thread: http://www.plctalk.net/qanda/showthread.php?t=61189 In the Processor...
5,063
Hello Everyone, I am having issues with getting online on my PLC5 file (RS Logix 5) and everytime I try to get online, it asks me to manually...
2,151
Dear Sirs, It is possible get online changes or editing the values ​​for Raw Min and Raw Max about a 1771-IFE Analog Input Module on PLC5/40E in...
2,248
