Online Simulator Problem
blubldedblu
Nov 2009
Phils
Im using OMRON CX Programmer 7.2c
My PLC is CP1H
My OS is Windows 7 64 Bit
Everytime I try to simulate my work online, it says failed to connect to PLC.
There should not be an error since im just simulating it and when simulating, no plc should really be connected.
Please Help. Thanks in Advance :)
CX-Programmer is not yet compatible with Windows 7 - it will be shortly - probably late this year/early next year.
NO Omron software will run successfully on a 64 bit operating system. The comms problems you have encountered will also happen when trying to connect to a PLC. 64 bit is not really useful in industrial systems. You could try compatabilty mode but I do not believe it will work in real life.
Thanks a lot! compatibility mode works for the online simulator. That helps a lot since I have a deadline on school for my program :)
Hello, I am trying to use the pulse outputs to control an external servo or stepper drive that accepts pulse and direction inputs from the PLC...
1,995
Just want to know. Does this PLC online simulator works? If so, must I accept a download (of software or application) to use it?
1,994
Hi All, I have migrated to a new laptop and today tried the simulator for the first time. It seems no matter what I do I cant get it to download...
6,110
I found a post asking about RS500 and EB8000 in online simulate and am trying to do the same thing.The post said to shut down RS Linx so it would...
2,280
I want good sample PLCS.net Online PLC Simulator but there are no files when I want to open from server Are there other places you can download...
2,105
