op17 #40 tranfer error
parco
Apr 2004
Karachi Pakistan
30
kindly tell me the description of this erroe also red light is on at my olc which is conected wtih s7-4oo cpu 412-2, plc is also having problem not communication between the rack the im at rack o is having greeen light flashing n im at rack 1 having green n a red light EXT fault.
thanks for ur commnets in advancxe.
faisal
[email protected]
faisal
Have a look at the hardware diagnostics of the CPU and you might find the cause of your problem.
I think that the #40 transfer error is a communication error between the OP and the PLC.
What is the state of the LED's on the CPU?
I appreciate that English is not your first language, but without punctuation I was having problems reading and understanding your post.
If you try to explain the problem with the PLC and remote I/O (I assume you have remote I/O as you mentioned 'im' (ET200?)) we might be able to help you further.
Paul
I am receiving the following error message on the Simatic OP17 $545 DB 32b 41 3 not avail. Before the restart that this HMI always does...
20
6,233
Hi. I am looking at a future project of migrating some OP17's to some newer HMIs. I have briefly looked at this & it doesn't seem as easy as I had...
2,309
Does anyone have the old ProTool software from Siemens? I was wondering if someone could open a project for me or sell me the software. From...
7,965
2,863
I want to up load progam from old OP 17 to PC and then down load to new OP17.For this I need software,Cable connection lay out and the...
1,692
