Opc ae
nandgate
Nov 2012
Hyderabad
Dear Friends,
I want to create an OPC AE Client using MS Visual Studio 2010 (VB). I have no problems with OPC DA Client (it is working fine). But i am stuck with the Alarms and events part. Can anyone guide me with some sample code??
sorry for my bad English .
with regards,
Nand gate
Won't you need the specification from the OPC foundation?
What other resources do they offer?
www.opcfoundation.org/
If you have already developed the OPC client, might I suggest using an OPC server with A&E capabilities.
http://www.eternity-sales.com/kepware/alarm_and_event_option.htm
This is a "plug-in" to the server, which connects the client application to devices through its library of communications drivers.
What PLC are you using? This will determine what driver you will need for the server, thus enabling you to use the Alarms and Events plug-in.
Why reinvent the wheel?
Disclosure - ESI is a Kepware distributor.
I am using Simatic Net OPC Server (which is communicating with a Siemens PLC on Ethernet) and my manager is not interested in buying a new server (cause there is a provision for A & E in Simatic net). I am through with the configuration part, i need help only with the code.
Sorry for my bad english
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
43
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
273
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
229
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
139
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
195
