OPC item paths in Simatic.Net OPC
Jontatas
Nov 2008
At work
Hey all!
I'm spanking new here and I couldn't find the answer here to my question, so I'm trying a post.
I have a Simatic.Net OPC server set up and it's talking to a S7-300 over S7 Protocol using symbolnames.
If I use the OPC scout everything looks dandy, part from one thing.
I can't find the exact path to use in a software OPC client to access the symbolnames.
All I can see is the data blocks and memory locations etc.
For example:
S7:[connectionname]DB201 would work, but
S7:[connectionname]Symbol_Name won't.
Is there a way to find the correct names/paths or am I screwed (ie I can't use symbolnames)?
/Jonte
[Edit] I shouldn't have put that in, now I get nothing on any path/name. Everything still looks nice in OPC Scout. Totally dumbfounded now...
I am looking for example code , c#, Java, VB , that demonstrates how to construct a complex item , for example of a Rockwell Logix User Defined...
1,397
Hello, I have problem with matriconOPC configuring. I made project in Proficy Machine Edition and there export variables to TopServer...
1,328
Hello I've been using RSLinx OPC Server to read/write tag values to/from a VB6 program, but we've been wanting to move to the...
6,887
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
46
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
275
