I know that an opc server is a software, but I thought the plc providers would develop them for their PLCs.
I was looking for an opc server for the LS GLOFA-GM series.
Thanks for the tip Mark. I'll try it. Hopefully it works with the GM series.
I am not positive because I have not tested with a LS GLOFA-GM PLC but, I find references like:
GLOFA-GM/New Master-K Cnet Serial Interface
GLOFA-GM/New Master-K CPU Direct
The above figure shows system configuration to connect GLOFA-GM and NEW Master-K PLC using CPU Direct
Warning: In case of Using Loader Port, Only above 3 wires have to be connected. Other wire connection except above 3 can cause controller’s malfunction or abnormal state.
which leads me to believe communication is possible. If you have any problems please contact [email protected] for assistance.
