What difference between RSLinx Enterprise and OPC Data servers
alpine
Dec 2011
Bangkok
51
I use RSLinx Enterprise in FactoryTalk View SE to retrieve tag value from CompactLogix PLC as follows;
1. I use RSLinx Classic to connect to CompactLogix PLC by EtherNet Device driver.
2. I use RSLinx Enterprise to Add Device Shortcut to CompactLogix CPU
These steps work properly.
However, I suspect that the relation between RSLinx Enterprise and RSLinx Classic same as the relation between OPC Client and OPC Server or not ?
anyone can suggest me about this relation
Thank All persons
alpine
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,415
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,048
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,974
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
817
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,838
