OPC specifications question
atomtm
Jun 2014
Germany
130
Hello everyone !
Would an application supporting OPC DA 3.0, support the OPC DA 2.05 specs too?
Thank you in advance !
Hello,
An interesting question. The OPC specification has required interfaces and optional interfaces.
To be one version or the other you must have the required interfaces to pass the conformance test for that version.
Someone could make a server that has all the V3 required interfaces and none of the V2.
Which leads to the answer, no. Has it been done or practical, that is a different question.
I could see someone making a new V3 complaint server and not implement the V2 interfaces.
My2c.
Honeywell's paperless recorder had an option for an OPC 3.0 DA A&E server built into the recorder.
No one ever got it to work with any OPC client that was considered OPC version 2. (I never understood where one could even determine the OPC version level on a conventional OPC server).
Honeywell's OPC 2.0 DA server that was part of their Windows application software package works OK with OPC 2 DA clients.
From that experience, I concluded that OPC is not backwards compatible.
Thank you very much ! I appreciate it !
Hello,
Yeah or the other way to look at it is the V2 clients are not forward compatible, which is not uncommon in most software.
From the stated example, Honeywell did not include V2 interfaces, excluding all V2 clients.
That is unless you have a server that incorporates all the OPC standards...
  • Application Connectivity: KEPServerEX has been enhanced to provide the widest range of connectivity of any server product available. KEPServerEX supports the following client server technologies:
OPC Data Access Version 1.0a
OPC Data Access Version 2.0
OPC Data Access Version 2.05a
OPC Data Access Version 3.0
OPC Alarm and Events AE version 1.10
OPC Unified Architecture (UA) Version 1.01
FastDDE for Wonderware
SuiteLink for Wonderware
DDE Format CF_Text
DDE Format AdvancedDDE
NIO Interface for iFIX
http://www.eternity-sales.com/Kepware/kepserverex.htm
Disclosure - ESI is an authorized Kepware Distributor.
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
46
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
275
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
229
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
140
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
196
