Open collector encoder to Trio differential line driver input
RoTaTech
May 2003
Cobourg, ON, Canada
418
I need to immediately build a circuit, to use an Omron Open collector single-ended encoder to Trio differential line driver input.
The encoder will take anything from 5-24V supply; and has A,B,Z
The Trio MC206 needs 5V differential/RS422 input: A, A/, B, B/, Z, Z/
Anybody dummied up something similar? I've not time to buy, just to build.
Rob
Rob
Have you tried tying the NOT inputs to the P/S common?
Hi, I would like to connect an encoder to Yaskawa A1000 drive. I have a Open collector type encoder and Yaskawa need line Driver output encoder...
1,019
Hello, I have a 1734-ik module and trying to connect with an incremental encoder. After getting the module I realized that my encoder is open...
1,638
I have a Red Lion model ZMD encoder which I would like to interface to a 1756-HSC card in a Logix rack. The input connection details are a little...
2,530
Is it possible to interface an encoder of open collector output to a SIMOREG 6RA70 drive? Any suggestion / help will be appreciated. Shyamal
1,526
We use a Turck encoder with Siemens or Allen bradley PLCs on our products. I use HSC instruction on the PLC to get the pulse count coming from the...
7,861
