Open Rockwell pva file in FT View
aand74
Dec 2005
Deinze
131
I have a pva file (of old Rockwell panel) that I want to open.
I do not have Panelbuilder 32.
Can I open this in Factory Talk View, and if so, how?
I do not want to download the panel again, it is just for looking at the screen and tag configuration.
If you have FTView Studio Machine edition, you can import the pva file.
Open FTView ME, select "new" application, give it a name, then clock on the "import" button, it then gives you options for pba, pvc, pva or med files, then go and select the file you want, and follow the on-screen instructions.
I believe you have to start a new project, and the option should be there. Are you trying to build it for a new panel? Like an upgrade? If not there isn't much good in doing an import.
Open View Studio, Choose to work with Machine Edition, On the next screen that offers to open a project, choose the 'new' tab, give it a name and that should enable the 'import' button.
Downloaded RS Logix 500 , now cannot open Rockwell Software"Error Logging Security" I have RS Logix 5000 and Factory Talk View Studio , and it...
10,484
I have to setup a computer to edit a .apa file which runs on a Panelview Plus 1000. The hmi is made in software version 7.00. Which software do...
20,438
The text of the error is: "Failed to open file '<File path and name>.ACD'. The project file contains an object whose format cannot be converted to...
19,115
Guys, I have got a small problem with my Rockwell Software (again)!!!!! Basically I can't get anything to open. I have tried opening RS Logix...
18
9,157
Dear all, For a very urgent project I’m looking for support for an Rockwell / Allen Bradley 1747OC open controller. This PC based PLC was in...
4,127
