Operator Binary Interface
durks
Apr 2005
I'm trying to interface to a laser and do program selection w/o a PLC.
I'm trying to select programs 1-32 and it's a binary format. Mistakingly we bought 2 thumbwheel switches to have the 2 digits and the output was BCD which once you get to 10 is different than binary.
Wondering if anyone might know of a hardware solution to convert BCD to binary or of a Operator interface that I can select a numeric value and output the binary values.
BCD is binary, but is restricted to the decimal values of 0 - 9 because the decimal value is coded in binary. If you are looking for true 4 bit binary switches, you need to get a switch that is capable of outputting those values. You do not need to convert BCD to binary unless you input the BCD value into a PLC and then need to use it as binary once in the processor. In that case, there are instructions in most PLCs that will convert for you, but I do not believe this is what you are seeking from what you said in your post.
Now to select programs or anything else with a thumbwheel type switch from 1 - 32 you will need a switch that has more than 4 terminals since that will only take you from 0 - 15. Getting up to 32 in binary takes bits, 1,2,4,8,16 and this is only 0 - 31, so to get to 32 you have to have a 6th bit. Good luck!
You could build a circuit with ICs to do the conversion.
I'd recommend just buying the proper thumbwheel switch though... :nodi:
-Eric
If I could find the proper thumbwheel switch I'd be all over it, but I can't find anything that is true binary and not BCD.
Use 0-7 on the low order switch. Only wire the lowest 3 outputs. Then use 0-3 on the high order and wire the lowest 2 outputs. Now write up a simple table for the decimal to octal conversion and post it by the switches.
Number High Switch Low Switch
0-7 0 0-7
8-15 1 0-7
16-23 2 0-7
24-31 3 0-7
You want the operator to actually have to read? This is automotive... they don't do that :oops:
The w/o a PLC part is gonna make it hard to achieve without custom building something. Why not get a Micrologix1000 and use it for a BCD to binary converter?
I see your dilemma... And see no 'simple' solution... :(
Similar to Bernie's idea, you could use hex thumbwheels and get from 00 to 1F. In this case, since you're only using 0 and 1 on the upper digit, it could be replaced with a toggle switch to select between the two 'banks' of programs (0-15 and 16-31).
Realize that although you can add a stop to limit the upper digit to a range of 0 to 3, you can't prevent someone from selecting programs 32 through 39. Your laser will 'see' these as programs 0 through 7... :oops:
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
23
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
266
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
743
Hello All, We have assembly line and our supplier building automated line on top of it we are interfacing mes system. Our automation supplier...
289
Has anyone setup comms between an operator terminal expert hmi (model doesnt matter) and tia portal? Cant find much on the web. There is a small...
864
