Opinion on OPC Server for Cimplicity-Siemens
dYoast
Mar 2008
Kansas City
252
Hello to all. I have been reading the forum for a bit, but I did not see a specific post for my question.
I am working on integrating some Siemens PLCs into Cimplicity Plant Edition. After looking at the GE Fanuc forum, I though I would try for a good opinion here.
I have looked at Kepware and Applicom. I would prefer to have a software based solution to avoid problems with hardware updates and also enable the use of a laptop.
Please give some opinions on OPC Servers.
Thanks.
Hi dYoast.
I am not sure I understand your question.
OPC is an open standard, so in any OPC server will in principle work with any OPC client.
And OPC is a software standard working on Windows PCs, so it is in principle a software solution.
You may still have to use some comms hardware if you want to connect via MPI or Profibus. For ethernet, the normal NIC that is standard on any PC is enough.
I think the Applicom OPC server you mention is exclusive to an Applicom Profibus card.
What is it that you want to achieve ?
What network type will you use ? (MPI, Profibus, ethernet)
I will be using an Ethernet network.
What I am mainly asking for is opinions such as "I use x-brand and have had no problems" or "I tried z-brand and had problems".
I am simply trying to gather information before asking the company to spend money.
I use Simatic Softnet Ethernet Lean.
It works for me and is quite cheap too (half price or less compared to other OPC servers).
It is limited to max 8 connections.
Good morning. I would like a opinion about two components for developing OPC clients. I am developing a supervisory system opc client and a web...
1,525
I'm looking forward Iconics. I had previously extensive experience with Citect and little bit less experience with Wonderware. Pros and cons with...
845
It is rare that I ask for opinions. But here goes. Currently using a low cost NUC for an hmi. Looking for a low cost NUC or similar. thoughts
1,167
In my project, I have created a UDT for VFD driven motor. The UDT has elements of .SpdCmd, .ManSpdCmd, .MinLim, .MaxLim among others. The idea...
1,254
We are in a mechatronics class currently learning the beginnings of PLCs. There are a few things I think we are being misinformed on and I'd like...
56
22,614
