Optical laser measurement system
Oubax
Jan 2016
rabat
44
Hi All ,
I have machine that works with hydraulic cylinder, the position is transmitted via SSI bus between "Optical laser measurement system" and S7-300.
Due to maintenance problems, I have replaced "DME3000-111 Sick" by "AMS 304i 40 Leuze electronic" but the hydraulic cylinder Does not work normally, it can not reach the extreme positions (During automatic operation the cylinder should travel between the Dmin to Dmax ) .
I have tried to change the setting :
(Coding: Gray to binary / Resolution: 0.1 to 1 and 0.001 / Limit position / Offset )
With the Chapter 8 Display and Control in the above manual:
http://www.leuze.com/selector/ci_pag...9b457ec65ad66c
The best result that i get is that the cylinder reach the minimum position:
**Distance of the sensor=440 mm With Offset=55 mm
**Distance in the HMI=0 Good News because this minimum position coincide with minimum of the cylinder
**However when i command the cylinder to move to the maximum position, it stops before the maximum position ( Distance in HMI=Dmax and Real Distance of the cylinder < Dmax )
Now the problem is that there is a lot of possibilities (Parameters Combination ) and i can't find the right combination !!!
I need the help of someone has already worked with "Optical laser measurement systems", and what i should do as Initial Settings.
NB: I don't have the access to S7-300 program.
Thank you.
I think your problem is the scaling of the gray code sent by sensor
to the plc,it would be difficult if you cant see how the data is treated in plc code.
Can you check the parameters of the previous sensor?
Good luck
The cylinder doesn't work properly if i'm using the gray coding, I'm gonna try to check the parameters of the previous sensor.
Hi. I have a problem when Configuring the Fiber optical cable port P7 and P8. There are 6 field Scalance connected with fiber optical cable. They...
1,898
I am currently using 1 Optical touch button (from Banner engineering) OTB series and now looking to replace with some sort of single channel...
1,025
Hello, I'm wondering if anyone knows of an industrial sensor similar to what is used for positioning the pointer of a mouse (on an optical...
2,000
I have a DH+ connection that runs more than a mile underground parallel to a water pipe. Once maybe twice per year when soil conditions are just...
2,681
Hi all, Anyone can tutor me that how to write the formula for encoder to read the motor RPM(Omron PLC). Thanks in advance
2,720
