Hi.
I have a problem when Configuring the Fiber optical cable port P7 and P8.
There are 6 field Scalance connected with fiber optical cable. They works fine each other.
But, these field Scalance is connected to XC206-2SFP, it does not work.
XC206-2SFP can not configure local 6 Scalance by optical cable.
I have found one strange thing. When I put XC206-2SFP in the hardware configuration. it is always connected to two Profinet IO controller automatically.. Other scalance can be connected to one IO controller. Does it mean that I should trun on CPU L and R together, and two CPU should be synchronized to use XC206-2SFP?
I just turned one CPU. Should I turn on another CPU and have the redundant system to use XC206-2SFP ?
is XC206-2SFP used for hot redundant H-system to configure fiber optical cable?
You can see the picture below.
