Oreda data
jose7771
Jan 2005
42
hello frnds,
for obtainng failure rate from oreda , idealy which value, we should use (lamda,....mean,upper, ,lower, ) also what amount of repair time should we consider(mean ,min , max)
regards
jose
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
50
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
74
62
172
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
78
