Orifice calculations
Tom
In the same kind of questions, do you know about a formula to calculate the area needed for air blowing thru.
In others words, if you want to validate how much opening you need in a cabinet for x amount of air flow CFM to keep a low static pressure requirement for some ordinary cooling fan...
Q = A x C x k x √P
Q = cu ft / min
A = sq ft
C = orifice coefficient, 0.6 for square edged orifices
k = 21,094 for these dimensions
P = psi
Note that this is based on standard ambient conditions, density = 0.075 lb/cu ft. Density affects the flow, but for most purposes I ignore it. The formula for density effects is more complex, but I can provide it if you want. For most ventilation purposes all the other errors and assumptions overwhelm density effects.
Also note that the flow changes as the square root of P Twice the flow = 4 times the pressure.
awesome!
Do C is for the shape of the orifice or for the finishing of it ? For exemple do i have to put anoter coeeficient when using rectangular orifice or circular one ?
I spend a lot of time looking for this on internet and most of the links return me to home exchanger calculs to balance pressure inside the house...
C is a function of the orifice cross section, not it's shape. A square or rectangular hole will have slightly different characteristics than a round hole of the same area, but the differences are negligible compared to all the other uncertainties. If you get pressure drop calculations within 10% of reality you are doing pretty good.
The attached is the basis for my post.
Dear all, hope you are well, A friend ask my for he has an orifice is worked at hydrogen service with high flow after that he needs to use...
1,324
Does anyone know the formula for calculating the maximun flow through an orifice? The fluid in this case is water. I have the dia and K factor...
5,808
Good day, Orifice details d=92.36mm, max flow rate =120m3/hr, max diff =0-100mm wg. And my dp cell is calibrated to 0-25kpa. Is this correct...
1,912
Hello, what is the equation to measure gas flow across an orifice plate? i have a customer who has an orifice plate, DP transmitter, pressure...
4,769
Anyone ever use A dynamic orifice valve before? Its basically an orifice plate that is an iris that can change size...
2,519
