Dynamic Orifice Valve?
It sounds a bit like the rubber pinch valves sometimes used on cyclones to control the particle size cut in the mining industry. I have seen them a few times and they work OK.
Roy
Ive had a change to look at one of the prototypes at a show, and its an iris like on a camera (steel of course). It seemed to have good flow control. Ive never seen an iris act as a valve tho. They sure would be great tho, as with a diffy transducer they are flow meters and control valves, all in one tiny little package (they output the orifice size as a 4-20)! The price they were talking about is less then I pay for just a wuakee flow meter now, let alone a port valve and an actuator. So, im must say, im excited to try one out. THanks
matt
I haven't dealt with one of those in particular, but we have a couple flow control valves from Dennison Hydraulics that we use to control hydraulic flow and they work pretty nice. They have a built in closed loop control so they stay at the same position reguardless of pressure or flow changes. Ours is rather big though, I think its 2 or 3" inside diameter and is rated for 6000psi.
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
238
Maybe this is just not possible, or maybe I am doing something wrong. Background; I have a data array of over 1500 products. For sorting I...
765
HEllo, still satruggling with the curse WinCC Unified. See attached picture. I just want to change the fill colour from turqoise to grey and then...
482
I need assistance with writing a logic for sending data from a Station PLC using 1 MSG instruction to an AGC PLC in every cycle using a CIP Data...
586
