The Oscat library is for Codesys or Codesys based plc's as far as I know. I am not familiar with TIA and Siemens Plc's in general, are they Codesys based?
In theory, if you import the SCL sources into TIA, S7-300 SCL should work, I think. Or at least it should be pretty close. It won't have been optimized for Portal, but that's probably why no one has taken the time to do it.
