Oscat library for 1200/1500 TIA Portal
PLC
Sep 2002
NC
311
Anyone have or would mind sharing the above?
I went to the oscat website (and I have a login)
But I need to learn german :)
The Oscat library is for Codesys or Codesys based plc's as far as I know. I am not familiar with TIA and Siemens Plc's in general, are they Codesys based?
It exists for Simatic Manager 300/400/WinAC with SCL
I just cant seem to find it converted to Portal for 1200/1500's
Theres mention of it in the Oscat forum, but I cant read german
In theory, if you import the SCL sources into TIA, S7-300 SCL should work, I think. Or at least it should be pretty close. It won't have been optimized for Portal, but that's probably why no one has taken the time to do it.
I'm a very novice user of Bosch-Rexroth IndraWorks, and thus CoDeSys v3, and hit the ground running with the IndraLogic XM22 controller without...
2,349
Hello, a newbie here and a newbie to using codesys. I installed OSCAT to codesys 2.3. I want to use some functions from it, but one in the...
3,012
Hi all, I am the Bosch Rexroth version of Codesys (Indraworks V13). I have downloaded the Oscat library but cannot get it into Indraworks...
5,523
Hi. Have anyone used OSCAT (3.04) in TwinCAT? I get 28errors when compiling OSCAT code in TwinCAT. Anyone experienced this? The error is in...
1,667
Hi. I just downloaded OScat.lib for TwinCAT. However it seems like only a few of the functions described in dokumentation is awailable in TwinCAT...
1,705
