OT... Apple OS/HDD question please.
RussB
Oct 2003
Michigan
2,914
I know nothing "Apple"... Except for the kind we eat & drink.
My sister purchased a MacBook Pro and she has an HDD with backup photos etc. from when she had a Windows PC. She has asked if I could re-format the HDD for the Apple and I promised to look into it for her. All files have already been archived so no need to save anything on the Seagate HDD.
Looking for a link with instructions to either format for Apple with my Windows PC or her MacBook.
I found this but have not tried it yet, http://ask.metafilter.com/23808/please-help-a-mac-user-format-a-hard-drive-using-windows
does anyone know if it will work to simply delete the partition and plug it into the MacBook?
TIA! (y)
I found one potential answer with a caveat by formatting FAT32 both OS's can read and write however the largest file size will be 4-Gig.
Hopefully this works for her. (y)
FAT32 will do in both PC and Mac with the caveat of a maximum file size of 4GB and 2TB total for the entire drive; also, there cannot be any implemented security.
HFS+ is the native Mac format; you will need a Mac OS machine to format the HDD for HFS+.
After backing up the data elsewhere (off the HDD!) plug your HD into the Mac and open Disk Utility, which can be accessed by searching for it in Spotlight. Then, select your hard drive from the left sidebar. Now go to the Erase tab. In the Volume Format list, select Mac OS Extended (Journaled). Then, click Erase at the bottom to format the drive.
Thank you! And that was fast!
Come to find that this 64 bit version of Windows 7 no longer has "Format FAT32" or is it because the external drive is 500 Gigabytes? :-(
Anyone running Macbook with Parallels? For the record, I've been using a Macbook Pro with Parallels for the last 6 months and have had no SERIOUS...
3,408
Hi folks, We have 18 pineapple peeling machine called Ginacas in our factory.Each process about 72 fruits per minute.I want to introduce a cost...
2,005
Hello, Can anyone write up a procedure on how to configure the Apple's AirPort Express to hook up to a Allen Bradley PLC Ethernet network so I...
1,830
has anyone ever used a apple macbook to run allen bradley or omron plc or display software?
2,931
Has anyone used an apple computer VM fusion ware or parallels using windows xp running allen bradley software such as rs logix 500, 5000 and...
6,376
