OT - Autocad Electrical
James Mcquade
Oct 2007
Nashville, Tennessee area
3,683
Hi everyone,
this is a bit off topic and support has not gotten back with me.
I am using Autocad electrical and i need to do some mechanical drawings.
i used to know the command that would allow you to switch from the electrical ribbon to the mechanical ribbon and back again, now i have forgot.
should have wrote it down, but didn't
Would someone happen to know the commands to allow me to do this?
thanks in advance,
james
Click the hamburger in the bottom right, check off Workspace Switching in the menu. Then find the cog in the bottom right bar, click it and select a different workspace.
Or the command WSCURRENT
thanks so much !!!
you are a life saver.
i am using B.....cad and while the commands are the same,
i hate it, i have had to redo drawings multiple times die to the bugs.
company standard, no choice.
this time i WILL write it down.
again, Big thanks,
james
Hi Expert: I have used EPlan at previous job, now in the new job they use AutoCAD Electrical, just finished one training at Udemy, it is not good...
1,150
Is it possible for AutoCad Electrical to generate wire lengths, if e.g. paried with a 3D assembly from Inventor with matching part numbers? This...
2,711
Everyone, Due to covid-19, I am now laid off with no chance of rehire. all the jobs I am looking at want autocad electrical experience. I used...
3,707
For a novice at CAD who needs to learn to draw electrical schematics, is it worth the extra money for AutoCad Electrical or would you just start...
22
8,076
