OT: Cord grip bushing to accomodate large molded end connector
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
The picture should about cover it.
In the past, I have customized a cord grip bushing by splitting the rubber grommet and combining pieces from several separate kits, but for this application, I want to buy something that fits with minimal mods.
Any product recommendations? Stainless steel preferred....
Thanks,
Paul
I have done what you are describing around a mouse cable, whilst being able to pass the USB plug through the cord grip gland, the mouse was a cheap sacrificial item in a corrosive area, its lasted 4 years so far.
I used a 25 mm gland and got some sealed foam about 20 mm in diameter with a split from the center to one edge that I place around the cable and the tightened the gland.
I have even used the foam type ear plugs to fill the gap then tightened gland.
Take a look at this link
http://apgvision.com/productpages/cordgrip.htm
That link is just what I am looking for in this single cable application. Thanks for the links to the Roxtec stuff too.
Paul
Hello Everyone, I was wondering if anyone has any suggesting on getting Ethernet Cables with RJ45 connectors into control panels. Looking for...
1,783
What is the best way to run a pre-made cable through an enclosure? I have some servo cables with connectors on both ends. One connects to the...
7,075
I'm a beginner at this, I have points with x y z coordinates that I want to record on s7-1214 and use to move the axes for those points. How can I...
171
Good People of PLCTALK. I am trying to understand the pass-fail on one of our product lines. I was able to record the Cognex images on the...
248
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,185
