OT: CT transducer
the_msp
May 2008
Northern Ireland
1,271
I have a set of these:
https://www.i-s.gr/files/ND Clamp-on CT Brochure.pdf
Specifically M1.UM which outputs Voltage.
I am looking to use these Monday for some test measurements into a PQA however it only takes 1A or 5A Current inputs.
Are there any transducers available that will scale this for me?
I have one Rogowski coil here that will sort of let me away, but ideally I'd like 3 phase. My local supplier has no more Rogowskis' in stock right now.
Space is too limited for standard Open-coil CTs.
Something like this is close:
http://www.sil.co.uk/pdf/dtm3u.pdf
The load I'm measuring is motor FLC at 80A, but currently star-delta so a peak inrush is expected.
The PQA is a Janitza 512 Pro, and whilst I've only ever used 1A or 5A input, in the software it lets you select mA.... hmmm...
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
119
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,097
Has any used a ballistic pressure transducer with a PLC? I am not sure if it will capture the event that I need to use as a control. The device...
1,084
I am updating controls on a leak tester, from a SLC 5/02 to Compact Logix. The SLC used a DDV instruction to help scale a differential pressure...
17
4,429
I have a Pump 1 Current in my Local:5:I.Ch00Data address. I need to add this to my ladder logic program as the goal is to have it eventually be a...
1,471
